Baltic birch for dovetail nose block? http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=24539 |
Author: | Haans [ Tue Nov 10, 2009 5:15 pm ] |
Post subject: | Baltic birch for dovetail nose block? |
Been thinking of laying up some Baltic 11 ply 7/16" birch as nose blocks with a dovetail (mahogany) neck. Anyone done this? Does it work alright? Any disadvantages? |
Author: | Jimmy Caldwell [ Tue Nov 10, 2009 5:31 pm ] |
Post subject: | Re: Baltic birch for dovetail nose block? |
Haans, Lots of builders use Baltic birch for blocks, especially tail blocks. I don't see any reason why a neck block laminated to the appropriate thickness from Baltic birch wouldn't work also. You'd never have to worry about splitting one, although as long as the grain orientation is correct, mahogany blocks work very well. I've seen only a couple of failures in 30+ years and they were the result of abuse and not wood failure. |
Author: | the Padma [ Tue Nov 10, 2009 5:32 pm ] |
Haans wrote: Anyone done this? Does it work alright? Any disadvantages? Well Haans, to answer your questions Yes Yes and Non that me has experienced. I find baltic ply to be exceptionaly stable. By the way , me sure do likes your mandos. A1 work.` ![]() blessings the Padma |
Author: | Michael Dale Payne [ Tue Nov 10, 2009 5:34 pm ] |
What is a nose block? Neck block maybe ![]() Also the plywood will dull chisels faster for the same reason combined with the resin |
Author: | woody b [ Tue Nov 10, 2009 6:08 pm ] |
I've got 2 reasons I haven't tried baltic birch plywood for dovetail neck blocks. 1. Although the ply looks good, it doesn't look......normal when you look inside a guitar. I bevel the edges of my neck blocks and this would really bring out the......plywood look. 2. This reason may not be a cause for concern. It doesn't take much to hold a dovetail in, but 1/2 of the thin plys are end grain, and there's also the glue holding the plywood together. Is a dovetail mortise in plywood good enough to glue the neck to? Would the steam necessary to remove the neck, if it ever needs to be removed cause problems with the glue holding the plys together? I use baltic birch plywood for the tail block, but I've always used Mahogany neck blocks. |
Author: | Haans [ Tue Nov 10, 2009 7:08 pm ] |
Ah, yes Michael, neck block as opposed to the endpin block... ![]() Woody, your post may have answered my question. I was worried more about the joint and the endgrain of the ply. I've usually used mahogany to mahogany or maple to maple on mandolins, so maybe I'll laminate some mahogany in some creative way. I'm not really concerned about ply laminations look, eleven ply Baltic is a rather high quality product and It doesn't bother me much that it's visible if it does a specific job well. I've never subscribed to convention much on the inside anyway. It did occur to me that the Baltic may not be steamproof...I may drill a hole in a chunk and steam 'er up to see what happens. Paddy, thank me you (just a little Frank Wakefield talkward backing)! I will probably use Baltic on the endpin block. Thanks all! |
Author: | grumpy [ Tue Nov 10, 2009 7:08 pm ] |
Hans, don't go there! You'll be cursed forever when the time comes for resetting the necks of your guitars. Steam and plywood don't go well together. At all. Besides, baltic birch ply is too heavy for blocks; it just adds dead weight. |
Author: | Haans [ Tue Nov 10, 2009 7:20 pm ] |
Zat you Mario? Yea, probably not a good idea. Will stick with mahogany. I was a little concerned as I steamed a neck off yesterday and the mahogany looked pretty soggy. I guess Baltic birch would look like particle board after steaming... |
Author: | Link Van Cleave [ Tue Nov 10, 2009 10:20 pm ] |
Make your own out of Mahogany. Best of both. Wouldn't take long to glue up. Use a urea formaldehyde glue like Uni-bond for a stable rigid and water/steam proof block. I haven't found Baltic to be very stable. Rip a strip on the table saw and watch it take off. Panels warp very readily even if straight when purchased. If it displays any tameness it is that it's stable by nature of the type of construction not by the type of wood. The alternating grain in plywood is a great way to make a stable panel or piece of material. Mahogany is a very stable wood. Combine the two and ![]() Birch is a unruly wood plus they aren't using that high a grade of wood in plywood. Birch is strong but heavy. True in a small piece like a heel block you might not notice it but still.... Plus unless you have a immediate use for the baltic you have a lot of material for a little block. Plus (again) if you make your own you are not limited to a certain thickness. Plus (one more time) baltic is hard to shape, carve where as a home made mahogany ply block is easy.to shape. Plus (last time) mahogany is lighter. Link |
Author: | MRS [ Wed Nov 11, 2009 4:13 am ] |
The only thing that i think is wrong with a plywood blocks is their weight compared to solid mahogany. They are heavier. Edit: didn't read grumpys post where he mentions basically the same thing. |
Author: | Haans [ Wed Nov 11, 2009 8:16 am ] |
Well, flying in the face of convention again, I'm not that concerned with a few grams of weight as these are 12 strings and frankly, to be able to use .070-.014" strings...they are built relatively heavy with thick tops, large bridge plate and laminated braces. I have (with all your help) talked myself out of it quickly. The "aircraft plywood" sounds interesting, but I see it comes in 1/4" max and that would take a lot of layup with epoxy; messy, and that would get heavy. I guess it was just a fleeting thought on an overworked day... Again, thanks for the input folks! |
Author: | walnut47 [ Wed Nov 11, 2009 8:27 am ] |
Don't know if it would relate to nose blocks, but didn't Gibson use plywood for bridge plates for awhile - and the problem was that they were too stable - thus causing tops to crack? Walter |
Author: | woody b [ Wed Nov 11, 2009 10:13 am ] |
walnut47 wrote: Don't know if it would relate to nose blocks, but didn't Gibson use plywood for bridge plates for awhile - and the problem was that they were too stable - thus causing tops to crack? Walter Gibson used some kind of laminate for bridge plates on the guitars with adjustable bridges. I don't know it they used them in other models or not. FWIW Gibson used Spruce for bridgeplates in LGO's. I've replaced several of them. |
Author: | Randolph [ Wed Nov 11, 2009 1:39 pm ] |
I used a baltic birch bolt on fretboard extension on the guitar I'm currently working on. When I tightened down the bolts for the fretboard the first time, the birch delaminated right away (hardly any pressure applied). It didn't delaminate from the ebony fretboard but in the layers of the plywood. I just don't trust the glues and joints in commercial plywood anymore. The quality has come down in plywood in the past few years. The neck seems like a high stress area. I feel better about trusting my own joinery - for what it's worth. |
Author: | Haans [ Wed Nov 11, 2009 5:07 pm ] |
.220" ![]() ![]() ![]() That's thicker by quite a bit than my 12 strings! And get a load of that bridge plate!! Well, in defense of Gilson, their mandolins weren't any better... |
Author: | truckjohn [ Thu Nov 12, 2009 9:01 am ] |
I wouldn't hesitate to use Plywood for a bolt-on neck block.... I have seen every sort of wood you can think of including Spruce used successfully for bolt on neck blocks.... (Well, I haven't seen Balsa used yet...) I would be more careful with a Dovetail neck block -- as Mario said, Consider Neck Reset time Steam + Heat + Plywood = Delamination. Thanks John |
Author: | Yukon [ Thu Nov 12, 2009 2:12 pm ] |
Martin uses plywood blocks in their bolted and glued mortise and tenon necks. There is definitely a problem with the bolts loosening and the glue joints failing. However you are planning to do a dovetail so the mechanical joint should provide the necessary strength to hold the neck in place. |
